95 integra idle problems.
Old May 12, 2003 | 04:22 AM
Chucko's Avatar
TR Balla Donor Supreme
Default 95 integra idle problems.
I have a 95 gsr. the idle when cold jumps right to 2800 and drops slowly to about 2200 then drops to 900. Then surges back to 2500 so on so forth. I changed the idle control speed valve and that did not fix. I tested the ecu and it came back good. I have no vacuum leaks and all electrical is sending proper signal. It is not throwing any codes out???? any ideas???
Old May 12, 2003 | 04:35 AM
94Egsr's Avatar
idle air control valve...they are really expensive tho....im waiting to put my manifold on to fix it because the skunk2 will accept any iacv off any honda i believe...because there are 2 sizes
Aaron
~GST~
Old May 12, 2003 | 05:03 AM
Chucko's Avatar
What is the cheapest way to fix that?
