sohc vtec in crx help
Old Jun 8, 2003 | 11:20 AM
crix's Avatar
:mugen member:
use a integra 88-89 ecu pm7.........rev-limit at 7800rpm
I had this same ecu & a few other things
and dynod at 125hp to the wheels
Old Jun 8, 2003 | 11:39 AM
rangcrx's Avatar
engine building &best
but if you use a Usdm ecu you have to spend the money on a Vtec controller anyway so your better off just buying the vtec ecu...THe pw0 is the Jdm Ecu that came with the crx's b16's makes it alot easier we just did it into a 90 crx si sohcVtec works freaking great and with the Msd,ANd bigger throttle it almost keeps up with Dohc
i love AUTOZONE
Old Jun 8, 2003 | 04:31 PM
crix's Avatar
:mugen member:
if its a b16 ecu IT would be a PR3 if so then its running too rich ,but it will work
If the motor is a D16 then a ZC ecu is what will work best for
pre OBD,YES you will need to hook up vtec but if your cheap then you can use a toggle switch & relay($20)or another way
Old Jun 8, 2003 | 07:02 PM
stockls 15.4??what's Avatar
i want to convert to odb1 but i don't have a harness and i can't spend to much money on one right now
PLAY PAINTBALL LOCALLY
http://www.blitzkriegpaintballfield.com
^^^^^^Click There^^^^^^
Modified Racing Inc. (Blown99civicSi) John Solaro
https://www.tamparacing.com/forums/h...t=john+scammer
https://www.tamparacing.com/forums/h...acing-inc.html
Old Jun 15, 2003 | 08:52 AM
Sourskittle's Avatar
Where racing is a pleasur
I have an OBD1 dizzy, P-28 vtec ecu, and harness convertor.
I paid: $100 dizzy used
$ 100 p-28 ecu
$ $163 for the wiring harness convertor.
If you want all three make me an offer or if you can get a hold of a HF/Std. manifold I'll do a trade with some cash.
86' snapper electric powered lawn mower.
95' F-350 crew-cab powerstroke 5-speed 21.63mpg
03' G35 6-speed coupe. Grey on black.
02' wranlger apex edition with EFI 5.0L 302 SBF. 5.5'' lift, custom 4-link 8.8 in the rear, high pinion D30 front with locker.
A wise man once said, " I didn't wash my hands b/c my D**K is cleaner then ANYTHING, in that bathroom"
Old Jun 15, 2003 | 11:44 AM
i got the hf manifold if u wanna buy it....comes with heat shield and o2 sensor
Old Jun 17, 2003 | 07:17 PM
  #17 (permalink)
S.crix's Avatar
d : - L ......
if u want help let me know...
call 813-908-3681
my computer broke
so call...
u GUYS can SUCK my BALLS
