Coolant hoses compressing when motor is not running. Pic inside!
I just noticed this today when changing my oil:
I showed my father and he's never seen that before. He opened the radiator cap and air went inside and the hoses expanded back to normal. Now I'm thinking there is air in the coolant, right?
Happens with both the upper and lower radiator hoses.
Anyone explain why this is happening to my Eg/GSR?
Thanks!
Thanks!
K20a2 powered Midori 95 vx
You need to bleed the air out of the coolant system...Either run the car with the radiator cap open and add water as the water gets sucked into the motor or open the bleed bolt...
Zee
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
