Injectors
I own a 98 Integra GSR and I have a pair of crower stage 2 camshafts, crower valves and retainers, dc sports 4-1 header, dc sports cat back exhaust, dc sports cold air intake, msd ignition, distributor, nology spark plug wires. I also got my head port and polished. I wanted to get new fuel injectors and I was thinking about RC Engineering. Whcih pair of injectors for my car should I get?
Guest
Posts: n/a
You can't go much larger w/o a fuel controller such as an S/VAFC. I would suggest getting Hondata and getting tuned, I believe it requires 440cc's.
At the very least I would get a VAFC+310cc injectors and tuning that motor.
-- Some cam gears would prolly get you 6-10 more ponies with those cams as well.
Get a Fuel Pressure Regulator and gauge and hit the dyno...Bump up the pressure 2psi until you stop making power, then go back to the last setting...Get some Cam Gears and adjust them next, when you get the most power from them, bump up fuel pressure and see if you make power...If you do, keep going up and repeat the process...
Dyno tuning is great for this type of tuning, but the track should be the determining factor...
You don't need injectors...
Zee
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
04 Civic Si
01 Lexus GS300
