Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why?
Old Apr 21, 2003 | 07:09 AM
Hybrid93Hatch's Avatar
Question Was throwing just code 22. Now, 22 is gone and it's CEL code 21, Why?
I have no idea what is going on with my Hybrid. The other day the diagnostic threw code 22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch and I just checked it again this morning and now it's code 21 (VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve)
I'm going to check the wiring back to the shock tower and ECU and also the connection at the vtec solenoid...
Just have no idea why it would go from one code to the other. I did remove the vtec oil pressure harness the other day and plugged it back in. Maybe it was not on correctly and that is the problem with the solenoid valve
Be back in a minute......
Back ---> Checked the connections and everything looks good. Maybe time to take the car in to a shop
93 Civic Cx
98 GSR motor (usdm)
K20a2 powered Midori 95 vx
Old Apr 23, 2003 | 10:25 AM
Akkord29's Avatar
i had the same problem, either due to oil leak from a cam seal i had replaced, or my vafc. do u have a vafc?
01 Lincoln LS
01 Nissan Maxima AE
94 Acura Legend
Old Apr 23, 2003 | 03:09 PM
What exactly is a vafc?
Old Apr 23, 2003 | 03:47 PM
Akkord29's Avatar
a aftermarket vtec controller
01 Lincoln LS
01 Nissan Maxima AE
94 Acura Legend
Old Apr 23, 2003 | 04:28 PM
No vtec controller here.
I'm going to check the connections at the ECU, make sure the wires didn't get crimped / clipped between the harness and ECU, and also someone said their code 21 was due to a bad ground on the vtec solenoid. So, I'll check that as well.
If all else, I'm going to try my friends P72 ECU.
Thanks!
