D16z6 into a D15b2 89' HB problems
Old Apr 19, 2003 | 09:28 PM
Sourskittle's Avatar
Where racing is a pleasur
Default D16z6 into a D15b2 89' HB problems
We've swapped the motors and the Z6 is sleeping in the car right now, but it won't start for some unknown reason.
We've checked all the grounds ( fuel pump rely, tranny/battery, and valve cover ).
We are using an Si PM6 ECU, pm6 harness, dizzy, injectors, resistor box, and intake.
I have a V-AFC to control the V-tec part.
I swapped the Z6 fuel rail ( and FPR ) on to the Si intake.
Anyway, I was looking for some pointers as to why it won't start. I've put two days into swapping it and it just won't start for some reason.
The motor was running when pulled from its donor car, so its nothing "motor" related.
bleveret@tampabay.rr.com
86' snapper electric powered lawn mower.
95' F-350 crew-cab powerstroke 5-speed 21.63mpg
03' G35 6-speed coupe. Grey on black.
02' wranlger apex edition with EFI 5.0L 302 SBF. 5.5'' lift, custom 4-link 8.8 in the rear, high pinion D30 front with locker.
A wise man once said, " I didn't wash my hands b/c my D**K is cleaner then ANYTHING, in that bathroom"
Old Apr 20, 2003 | 07:15 AM
NChatch's Avatar
i stepped on my weiner!
are you getting any spark, or fuel
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Apr 20, 2003 | 09:28 AM
Jake1234588's Avatar
A.T.F.
its getting spark and fuel but wont start it acts like it starts then shuts off just that fast then just wont start after that and you just keep turning the key and nothin...
2006 8.0L Up Armored Suburban
2000 Integra LS
Old Apr 20, 2003 | 02:18 PM
KJ's Avatar
KJ
bored at work
Is the d15b2 the dx engine? If so you cant just swap the si harness in, won't work. You'd need to use the dx harness and convert to mpfi.
If the d15b2 is the hf then it is ok to use the si harness.
Old Apr 20, 2003 | 05:50 PM
A.T.F.
Well why would it not work see my friend had a dx we made it a Si harness,ecu,intakemanafold,and Distributor and all,and its ran like a mother,and on friday he got a ex motor and we put it in and we are useing the Si intake,and dizzy,ecu....so why wont it work what makes it not wont to start?
2000 Integra LS
Old Apr 20, 2003 | 06:19 PM
pimptightcrx's Avatar
it turns but doesnt start or no turnning at all cause if thats the case try tapping on the started had to do that to mine for a while till i got a new starter
Old Apr 21, 2003 | 04:29 AM
KJ's Avatar
KJ
bored at work
You can't just throw an si harness into a dx car. The dx interior wiring harness will not support the si engine harness. You need to convert a dx engine harness to mpfi.
Old Apr 21, 2003 | 05:33 AM
NChatch's Avatar
sounds like you might have a timing issue as well, i still think you have to convert the dx harness to an si, and the same with a sohc, or dohc vtec motor, unless you buy a repinned harness, i think, i may not be sure, but i think there are 2 white wires in the dizzy clip, that you have to swap positions, i think the way it is, it is firing 180 degrees off, this happened on my dx zc swap.
owner/operator
Old Apr 21, 2003 | 12:58 PM
A.T.F.
NO! we swapped the harnees and did all the multiport shit,we re wired for the Si ecu thats not the problem,but the 180 out sounds about right i will look itto that thanks
2000 Integra LS
