bad thermostat???
Old Apr 13, 2003 | 09:40 AM
99B16Si's Avatar
Default bad thermostat???
i dont have much experience in the broken thermostat field so i was wondering what some characteristics of a bad thermostat were.
obviously overheating is the major one.
one thing i also noticed was when i take the radiator cap off and let it warm up for a while it will start to overflow slowly out of the radiator. then itll go down and the coolant will start surging about every 3 seconds. it will go down then it will shoot up like a fountain and it will repeatedly do this until the level just gets too low and the surging coolant doesnt reach the top of the radiator.
i was thinking it might be a blown headgasket but the car doesnt smoke at all and it runs perfect other than the overheating problem. and i know it doesnt necessarily have to smoke when the headgasket is blown but its usually a common symptom.
any ideas????
Old Apr 13, 2003 | 04:17 PM
Young,Fablous,&Broke's Avatar
The cooling system is under pressure, thats why it overflows, the cap keeps it from doing that.
Old Apr 13, 2003 | 05:39 PM
95civex's Avatar
Sorta Kinda O.G.
...this was just my problem the other day....exact same thing was happening to me...I was pissed because i was thinking head gasket too....but changed the thermostat...and everything is fine so far...so that is probably your problem.
Old Apr 14, 2003 | 10:01 AM
99B16Si's Avatar
thanks for stating the obvious. dont reply to my question if u dont know the answer and just want to be a wise ass
i took out the thermostat and its fine now...weird
Old Apr 14, 2003 | 12:03 PM
umm oooo k? You asked why it over flows, and i told you. Not everyone knows a cooling system is under pressure.
Old Apr 14, 2003 | 04:17 PM
99B16Si's Avatar
sorry man just seemed like a wiseass comment at the time.
i drove around for about an hour today with the a/c on and the temp gauge never moved above 1/3 of the way up. must be either the thermostat or the switch. thanks
