!!!oil leaking through intake manifold!!!
Old Mar 28, 2003 | 11:15 AM
95civex's Avatar
Sorta Kinda O.G.
Default !!!oil leaking through intake manifold!!!
what would cause this,im getting water in my oil...could that manifold be doing this...please help
Old Mar 28, 2003 | 12:24 PM
0 0 0's Avatar
thats what i thought,but i didnt think that would make oil go through your intake manifold
Old Mar 28, 2003 | 08:42 PM
RONIN's Avatar
Tetris on a stick
youmight be getting oil in your coolant, and then the coolan going through the mani could be leaking, bad head gasket, bad walls, bad manifold gasket, etc
or you could be leaking oil from the valvetrain, that has just dripped to the manifold, or the sending unit could be cross-threaded and spraying onto the motor
Eat a live toad every morning, and that will be the worst thing to happen every day.
Old Apr 1, 2003 | 08:20 AM
0 0 0's Avatar
ok,this is what i got done...head milled 10,000...new headgasket,new manifold gasket...do you think that will clear up the problem???i sure as hell hope so...btw the block and cylinder walls appear to be in good shape
