impossible question none can answer
where is a good location to mount a sensor for a mechanical water temp gauge the sensor is about two inches long and threads into a sensor sized hole
... content in sig not work friendly
Thread an adapter into where the stock coolant temp sensor goes to feed a mechanical gauge and still run the stock sensor.
Gracie Barra Clearwater
if your sensor sized hole is 1/8 npt, then go to amazon and get a tee adapter. Screw your sensor in the top hole and 2 barbs out the sides, snip a coolant line, plug in, and you're done.
what ive learned is if you need a simple question answered you have to make your thread title chalenging i put this exact question up under a title along the lines of "temp sensor location" and did'nt get a single hit
