i need some tech help
Guest
Posts: n/a
i added an b&m fpr and gauge
to start with when i turn the car to the on location
it jumps to about 50lbs
and when i start the motor
it stays at about 59lbs
now no matter how high i adjust it or low i adjust it
it stays the same
this was all friday
now tonight i was gasing up i tried to adjusted it a lil bit
and when i got in the car the check engine light came on
i pulled the fuse the put it back in and still on
any ideas on either matter?
BTW i do have a walbro 255hp fuel pump
thanks
Hartman
it stays the same
this was all friday
thanks
Hartman
you did hook up the vacuum line to the top of the FPR, right?
1997 Prelude, H23A1 VTEC
Items for sale:
H22/23 block and all internal parts
4 5th gen Prelude wheels, 16x6.5, 5x114.3mm bolt pattern
More stuff for sale:
https://www.tamparacing.com/forums/showthread.php?s=&postid=472993#post472993
Items for sale:
hartman hartman hartman
ZMRacin...for the people since 1998.
typeZ
zionmotoracin@gmail.com
> #zionmoto #s1built #battlegroup3<
drag honda / drift soarer / road race benz
typeZ
zionmotoracin@gmail.com> #zionmoto #s1built #battlegroup3<
it sounds to me like you messed up somewhere on the installation. if the spring isnt seated right inside the regulator, it will bind and cause your problem. to reset the ecu (it will return though) you pull the "Back up" 7.5a fuse from the fuse box under the hood.
come by the shop soemtime and i will try to help you out
RIP Tim. i miss you, buddy
looks like that 255 high press is coming back to haunt you. put the stock pump back in and stop aimlessly putting parts on your car you don't need, or don't know how to use.
