anyone chipped thier ECU ?????
Old Mar 21, 2003 | 06:37 PM
NChatch's Avatar
i stepped on my weiner!
Default anyone chipped thier ECU ?????
okay i ordered one of those chips from a website and when i got it the rom socket was like a couple pins shorter than my stock one, and the prongs were like twicw as wide too. has anyone chipped thier shit? i have a P28, and the chip says it fits P08,P28,P30,P61,P91.
can this be right, if anyone knows about any of this chip crap let me know. i know how to build circuit boards and stuff and im pretty competent but this just doesnt look right.
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Mar 23, 2003 | 02:19 PM
NChatch's Avatar
help please
owner/operator
Old Mar 24, 2003 | 07:42 AM
NChatch's Avatar
understand completely, what you mean, i was just wondering cause we were fucking around with mine and now i have a 4000rpm revlimiter, and just wanted to see if anyone else had any similar type of affects on thier ecu.
owner/operator
Old Mar 24, 2003 | 05:52 PM
NChatch's Avatar
thanks, in my drag crx i run a set up called speed pro, from a mustang adapted for honda windows based software, and every little thing you can imagine, its nice it even has the boost, and NOS options for progressive controls, but right now my hatch(daily driver) cant move due to this bullshit chip thing that cant be fixed, or at least i cant fix it, i need some help
owner/operator
Old Mar 26, 2003 | 02:19 PM
drift's Avatar
Hatorator
go to RadioShack and get a socket. it's a 26 pin IC socket.
when you desolder the pads on the circuit board, be careful and use low heat or you'll pull the pads off the board.
there's 2 pads that will be difficult to desolder, so be patient.
lastly, use a LOT of solder when you solder the socket in... the mainboard is dual layer, so the solder has to flow thru to the other side of the board. if you dont use enough, obviously you wont get contact and you'll have to start all over again.
i HIGHLY recommend you use the socket... as you will be able to remove the chip at a later time without soldering, and you'll be able to convert over to Hondata easily.
1997 Prelude, H23A1 VTEC
Items for sale:
H22/23 block and all internal parts
4 5th gen Prelude wheels, 16x6.5, 5x114.3mm bolt pattern
More stuff for sale:
https://www.tamparacing.com/forums/showthread.php?s=&postid=472993#post472993
Old Mar 26, 2003 | 06:07 PM
NChatch's Avatar
thanks but i bought a kenkji
owner/operator
