radiator fan help
Old Mar 20, 2003 | 04:51 PM
juicyj's Avatar
Default radiator fan help
I’m having problems with my radiator fan in my 89 crx si with a b16a swap, I have checked my fan and my fuses and their both still good but the fan still won't turn on can anyone help?
Old Mar 20, 2003 | 06:22 PM
spoonfed's Avatar
Tha numba one stunna
my crx had the same problem so i wired it to my ignition switch so it runs whenever the engine runs everyone said i was going to burn up my fan i ran it like this for two years sold the car i saw the kid who bought it and it still works just wire it like that
... content in sig not work friendly
Old Mar 20, 2003 | 07:56 PM
accord95's Avatar
USMC
same with mine, wired to the ignition.
TR happily married crew-member #2
___________________
Originally Posted by Troux
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Old Mar 21, 2003 | 05:47 AM
civicracer901's Avatar
B16ACRX
same here, runs fine been running like that for about 3 years now and temp. stays low.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Mar 21, 2003 | 06:30 AM
Stephan's Avatar
how do you wire it to your ignition switch>?
DSM Part Out
Old Mar 21, 2003 | 06:45 AM
KJ's Avatar
KJ
bored at work
check the relay. It could also be the fan motor itself, did you hook up the fan switch coolant sensor when you did the swap?
about running the fan constant:
Your ecu gets a reading from the TW sensor, which is a thermoresistor. If the motor stays too cold the ecu will think the car still has not warmed up and it won't run as well as it could. I'd find out why the fan is not working and fix it.
