gauges
very simple my friend right next to your oil filter is a senser unscrew this you'll need a T fitting you can pick it up from any auto parts store made by sunpro put the stock sensor on one side and the one for your gauge on the other as for the temp gauge you need to remove the oil pan drill a hole on the back by the drain bolt 2" from the bottom install temp senser and all you have to do is run your lines
... content in sig not work friendly
