Hondata questions!!!
ok...whats the difference between the s100 system with boost and Hondata 2b with the boost option? or are they the same thing? I have dsm 450cc injectors(which i need to get blueprinted) and an integra Ls motor with a drag 3 kit. with hondata how much boost would be safe to run? and how much safer will it be with hondata and stock internals? Where can i buy hondata and are there any group buys or n e thing ? Thanks
"There are chords in the hearts of the most reckless, which cannot be touched without emotion." Edgar Alan Poe
Guest
Posts: n/a
Talk to Vapor. He is an authorized Hondata dealer.
Look in his sig for his number (not open mondays).
s100 is the newer system, it is also the BASIC system. s200 would be the system you want if you plan to upgrade other options such as datalogging.
2b is the older not-sold-anymore system (IIRC).
With Hondata, I believe John has had LS motors dynoing 270whp on stock internals. How much boost? I would GUESS 12 would be safe on stock internals and pump gas WITH Hondata.
How much safer? Infinately safer then NO engine management. Hondata has really nice features like boost cut. =)
No group buy ins that I know of.
Hope I've helped you out some.
