LS VTEC question
eh, the b16 pistons would not be legal.
and I think the idea of an ls/vtec would really be stretching the rules.
is the ITR in the same class?
If so I would consider ITR pistons and cams in a gsr motor, you will get decent gains from the bump in compression and cams.
I don't think itr's are in the same class. I haven't looked at a rule book in a while. I think a straight up gsr would be your best bet.
Gracie Barra Clearwater
US ITR pistons do make a decent difference in a GSR motor.
I know of a certain 4DR Teg that runs mid to low 14's with just those mods and a cat back exhaust.
Originally posted by BodyRollin'
well in the class that i am in in auto x (STS) you are allowed to swap parts from any car to any other car as long as they are on the same line (meaning that when prepared equally they end up in the same street prepared class) so it would only make sense to take advantage of the rules and get the most power by either swapping in a GSR motor or building lsvtec by using only GSR parts (aftermarket parts would put me in street mod, which is a class i cannot yet afford to be competitive in) so im wondering if you can effectively build a decent ls vtec using only GSR parts or if it wouldnt be worth the time/effort and to just save the money and swap in a GSR motor.
IIRC for Street Prepared you have to swap over the entire GS-R engine to be legal in CSP. once you mix & match parts from different trims i think it puts you into prepared/modified.
(you can swap an engine, as long as the engine is available in another trim of the same car.. IE, you can put a CRX Si engine in a DX or HF chassis).
in that case you may be more competitive by just going straight-up B18C1.
Shawn
The answer to your question is sqrt(pi)
Shawn
