Please Help with Steering
Before I did my swap I had power steering. Now I don't. I have a non-power steering rack. I have everything off except for the part that connects to the steering colum. I don't know where to unhook it. Can someone please help? I think that its under the dash but I don't know. Please help.
Thanks,
Thanks,
" Nitrous is like a hot chick with an STD, you wanna hit it, but you know what the consequences might be "
under the dash by the pedals you need to remove a plastic shield around the steering column. The column has a splined shaft that needs to be removed. There is a 12 mm pinch bolt that holds it together. Remove that and with a little force the column should seperate. Good Luck.
Gracie Barra Clearwater
