Compression Numbers/ Leak Down?
Old Mar 1, 2003 | 09:17 PM
hybridsi's Avatar
Default Compression Numbers/ Leak Down?
I recently did a compression test with bad results!!
High compression ls/vtec.
C1= 125
C2= 120
C3= 250
C4= 250
after adding oil to 1 and 2 they both jumped up 250.
Is this a sure indication that my rings are bad or possible cylinder wall problems?
Should I perform a leak down test to further narrow the problem.
Yes it is consuming massive amounts of oil.
Any advice would be great.
Zach
"Friends LET friends get MULLETS!"
Old Mar 2, 2003 | 05:28 AM
2qk4u's Avatar
type-r pistons?
i hit 260-260-260-255 i think with itr pistons
sounds like you gotta tear down this sucka and rebuild it.
u cant hone the block withthe crank in there, not a good idea.
Old Mar 2, 2003 | 08:08 AM
Bill's Avatar
Livin' in Seattle
Originally posted by Vapor
C1 and 2 need to be honed, and re ringed. Not a difficult procedure.
But it ain't no simple "oil change" either.
Bleh to internal work.
Old Mar 2, 2003 | 03:10 PM
civicracer901's Avatar
B16ACRX
so how much would a job like that cost for someone else to do it? I think colen (< name spelling?) was going to just change my rings for $300.
WTB:A clean 90-91 civic hatchback. Red or black or white in color. Good exterior. Looking to spend around $2,000.
Old Mar 2, 2003 | 03:29 PM
B16ACRX
Who is recomended?
