LS BLOCK Questions
Old Feb 27, 2003 | 05:09 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
Default LS BLOCK Questions
im need replace my bearings in my motor. so i figured why not throw some type r pistons in there for some more compression. first question is, will they fit with having to do any modifications? next is i think my crank has gone to shit. so i was offered a really good deal on a b20 crank. will that fit and work with my set up? will it make a difference in power? am i better off shaving my crank down? please respond ...........thanks
Old Feb 27, 2003 | 05:41 AM
KJ's Avatar
KJ
bored at work
rule of thumb: never shave Honda cranks. I light micropolish is ok but never shave.
b20b/z (crv) crank = 90+ls crank
b20a (old prelude/accord) crank = stroker crank (95mm), not a good idea
itr pistons need to be modified to run on ls rods. Get usdm b16a pistons which works out to about 11:1 compression w/ an ls head. The b16a pistons are a direct fit on the ls rods and the compression will be higher. I think type r is about 10.5: but I don't feel like doing the math now.
Old Feb 27, 2003 | 06:15 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
so no shaving ls crank. i cant really do much about the pistons because i already got them. but my set up will work?
B18a block, B20crank, usdm type r pistons and ls rods?
tamparacing.com
Old Feb 27, 2003 | 07:35 AM
JJFreshyZC's Avatar
TR Shop Mod
Ya I would like to know if this would work. I did not know you could put B16 pistons on LS rods and get 11:1 compression. Is this correct? Just curious as I have not heard of this before. Is that with a stock LS head and bottom end except for the b16 pistons?
Old Feb 27, 2003 | 07:48 AM
2qk4u's Avatar
KJ, you can shave a honda crank, BUT, they put some kinda of coating or some shit on the crank my dad said. and once you pass a certain point on the crank its all gone.
the crank is nitrated he said ( some sort of hardening process)
Old Feb 27, 2003 | 07:49 AM
2qk4u's Avatar
b16 pistons WILL work on STOCK LS rods.
im using that same setup for my LS block. i have my head milled also for my desired 11.7:1
Old Feb 27, 2003 | 07:50 AM
2qk4u's Avatar
ALSO get ARP BOLTS
Old Feb 27, 2003 | 07:51 AM
2qk4u's Avatar
type-r yields 10.8 in an LS MOTOR and JDM-R yield 11:1 but the pistons need to be cut to fit the LS rods which is 40$
Old Feb 27, 2003 | 07:55 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
Colin is building it for me. so i know im in good hands.
will there be a big difference between a stock ls motor and my setup? i mean as in tq/hp difference?
tamparacing.com
Old Feb 27, 2003 | 07:57 AM
2qk4u's Avatar
i ran 15.2 in my hatch with a STOCK LS Motor my 1st time ever at the track. so i KNOW the car coulda done 14.6-14.9 STOCK with a good driver. i also dynoed it. 121.5hp and 113 torque to the wheels STOCK!!. badass torque for a stock motor.
im gunna guess and say you should be 140-150hp and 120-125 torque.
my semi-built ls/vtec made 133torque
