A few problems
The cable from the transmission to the Speedometer is not plugged in, in my 88 crx si, where do i connect the cable to? and since ive gotten my clutch replaced my check engine light has been coming off and on, any help?
You are lifes biggest mistake.
The cable connects to the back of the tranny(below the rear motor mount)
The engine light is on because the speedo is Not pluged in...
Get the speedo working and erase the engine code &
your problem will be solved...give me a call if you want help?
u GUYS can SUCK my BALLS
