Skunk2 P28 Questions???
Old Feb 22, 2003 | 04:25 PM
Tampa^Bud's Avatar
Default Skunk2 P28 Questions???
I installed a Skunk2 chipped P28 today using a Kenji harness into a 2000 Civic Si. For some reason the idle stays at 2500rpm and the check engine light is on. Anyone have a clue as to what is going on??? Also, To check the engine codes, since I'm using a P28 should I look at the codes for a P28 ECU or the stock Si ECU??? Thanks for all your help.
Old Apr 9, 2004 | 01:47 AM
20whiteboy03's Avatar
i did the same thing adjust the throttle cable and the screw might have to do it a couple of times before it gets right but should be easy
my car is like my girlfriend spoiled and sometimes a BITCH, but she always finds a way to make me wanna keep her
Old Apr 9, 2004 | 07:38 PM
NChatch's Avatar
i stepped on my weiner!
i have a kenji shipped p28 with the same program and i had to reduce fuel by 20% at idle just to make it idle, from what i understand it has alot more fuel and timing.....
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Apr 9, 2004 | 09:22 PM
mtber's Avatar
1st off, the kenji p28 you have probably has a dohc 1.8L program on it that is running rich as hell like most of his programs do especially at the bottom end of the rpm span....
I recommend you resolve your Check Engine light issues by diagnosing them using a paper clip etc. The details are explained at http://phearable.net/tech under Troubleshooting
Once you resolve your codes & you still have problems, send the ecu to kenji & tell him what is going on. He will inspec the ecu & poissibly reprogram the rom chip for a 1.6L profile.
I have installed a kenji p28 into a friends 00 ebp. Only thing I did was tinker with his idle, besides that the car ran fine.
Good Luck.
