1995 Integra LSV swap question...
Hey TR, I'm completely stumped on what may be the issue with my Integra.
So I have a 1995 Integra that I just swapped my LSV into. Motor is a 00' Si B16a2 head with a '98 B18 LS block that I've owned for many years now. Harness in the car was built by my tuner only 2 years ago.
Problem: After swapping the LSV in the car spins over but won't fire. I hooked a noid light up to the injector clip and realized the injectors are not getting a pulse signal. I have a OBD1 P28 ECU with Hondata S300 and a OBD1 P75 ECU that was running my B20 and I have no injector pulse using either one. Checked fuses, made sure all sensors were plugged up, checked/cleaned ground at thermostat housing. I have 3 grounds on the car (valve cover to body, transmission to body and block to body. I have 50psi of fuel all the way to the rail, car has spark and battery voltage is great.
I'm stumped as to what to check next for not getting an injector pulse. Only steps I can think of to do next is to check the continuity at the harness where it plugs into the ECU and see if I have a bad ground somewhere in the car.
Nikon Owner
IG: @equippedphotography
FB: Equipped Photography1994 Integra RS - Stock LS/SOLD
1994 Del Sol - Stock D16y8/TRADED
1990 CRX Si - SiR B16a/TRADED
1998 Integra GS - JDM B20b/TRADED
1994 Integra GSR - Tuned H22a/TRADED
1999 EK Coupe - Backburner
1995 JDM Front Integra - Project
2014 F-150 5.0L - DD
Nikon Owner
b18c4dr
For Sale/WTB Honda & Acura
Sep 25, 2011 06:54 PM
Tlassiter
22
Apr 24, 2011 08:45 PM
