I need more power from a single cam! how?
Old Feb 19, 2003 | 06:02 PM
spoonfed's Avatar
Tha numba one stunna
Default I need more power from a single cam! how?
My last car was an 88 honda crx dx after scooting around on the stock d15 for a few months i bought a soch vtec motor for 150.00 dollars from steve former parts at crown honda in st.pete the swap went in within a few days due to some minor wiring problems and i ran high 15's with intake 2.25 header back exhaust and a center force dual friction clutch on a dx tranie...However when i found out my wife and I were expecting a babie i went to hondaland in tampa and traded it in on my 2000 civic ex the crx had a d16z6 my civic has a d16y8 wich produces slightly better numbers however my civic is much heavier and also has an automatic tranie making it much slower so far i have a skunk2 universal exhaust with stock piping gutted cat converter an aem cold air intake the y8 header is pretty nice no instead of replacing it right away I removed it and wrapped it with d.e.i. exhaust wrap all the way to the cat. Here's my delima whats my next move i had an adjustable feul presure regulator on my c.r.x that helped a little with power am i overlooking anything else? With all the single cam motors out there hopefully i can get some good input. Sorry this is kind of long winded
Old Feb 20, 2003 | 04:50 AM
98MODMTR's Avatar
TR Balla Donor Supreme
Break it into two, so you will have a DOHC
"The problem with socialism is that you eventually run out of other peoples' money." Margaret Thatcher
Old Feb 20, 2003 | 06:18 AM
Tits McGee's Avatar
is cooler than you
LoL
get a dohc swap.....problem solved.
Old Feb 20, 2003 | 10:20 AM
01Ls-RTeg's Avatar
Genius v3.015
get an extra cam
Yes, I do talk to myself, it is the only way I can have intelligent conversations.
Old Feb 20, 2003 | 10:46 AM
art's Avatar
art
E=MC-hammer
well man you'v seen my civic maby sometime I can swing by and have a look and I do have some extra stuff laying around not much but as sson as I shake this cold I will swing buy and turn some wrench's with you cool??
art
IM IN VA BITCH!!!!!!
www.rccustomz.com
Old Feb 20, 2003 | 12:16 PM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
sell the sohc. get a swap. dont wast your time with a sohc motor. plus all the money you'll spend on a single cam engine, you will run stock with a swap. but a ls swap. save some money go lsvtec and walk everyone. simple as that
tamparacing.com
