Cuz Im bored....
Old Feb 24, 2003 | 07:59 AM
2qk4u's Avatar
1-2k more HHAHAHAHAHA.
i revd my LS/vtec ALL DAY to 8500 with LS crank arp bolts and stock rods. you can even squeeze 9k outta it.
i go from experience and i say b20 crank
Old Feb 24, 2003 | 08:00 AM
2qk4u's Avatar
either way your not reving a stock b20 block past 9k reliably
u need sleeves for that
Old Feb 24, 2003 | 08:06 AM
2qk4u's Avatar
no speaddeamon made over 200whp all motor
Old Feb 24, 2003 | 10:39 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
wait a minute? i need a crank for my 93 ls motor. i can use another crank just as long as its b series?
tamparacing.com
Old Feb 24, 2003 | 06:29 PM
  #18 (permalink)
KJ's Avatar
KJ
bored at work
Why not just get a b16a block and sleeve it out to 84.5mm. It would be a 1.8L with a 1.74:1 r/s ratio. You could rev the shit out of it and it would cost alot less. B17a cranks are nearly impossible to find but you can pick someones b16a shortblock up for $150, hell I gave away one of my b16a shortblocks in running order for free before. There is no reason to use a b20 block, it's cylinder walls would be weaker too when compared to a sleeved b16a block.
Old Feb 24, 2003 | 06:34 PM
  #19 (permalink)
KJ's Avatar
KJ
bored at work
Yes and no, all the cranks will technically fit but you'd need custom rods for most setups. The deck heights of the blocks are different. If you put an ls crank and ls rods into a b16a block the piston will stick out past the block. A b16a crank and rods in an ls block, the piston will be several mm. under deck. Stick with the crank that is made for the block.
