Need Wiring Help!!!!!!!
Old Feb 17, 2003 | 04:23 PM
Stephan's Avatar
Default Need Wiring Help!!!!!!!
Ok i had a b16a put in a 90 CRX and the person that put it in didnt wire in my distributar right can anyone help me fix it??????????
Old Feb 17, 2003 | 05:06 PM
XpcorpC's Avatar
Vertically Challenged
What do you mean didnt wire it in right? Like the firing order? If so.. I think it's 1-3-4-2 going counter-clockwise.
Affordable Web Design, Graphics Design, SEO, and Internet Marketing. chris@splashmediaflorida.com
Old Feb 17, 2003 | 07:15 PM
Stephan's Avatar
no i mean that im throwing a code 9 which is either a bad dist. or its not wired into the ecu correctly
Old Feb 17, 2003 | 07:49 PM
S.crix's Avatar
d : - L ......
bad dizzy or sensor in dizzy==code 9
u GUYS can SUCK my BALLS
Old Feb 17, 2003 | 07:51 PM
Stephan's Avatar
i changed the dist and put a new one on and same code
DSM Part Out
Old Feb 18, 2003 | 07:30 AM
coleon's Avatar
RedNeck Refab.Inc
The wiring for your car should be the same as any standard b series wiring, My suggestion, would be to go over your cyp, ckp, and the tdc wires on dist. I have a chart in which you may be able to use, or atleast use to reference, but all the info as far as which wires go where is there. My other thought, is you used your old harness and laced in on as many others do, me my self I cut my old one, and when it came down to the dizzy, I had 1 of 2 choices, 1. Go color for color on cyp,ckp,tdc, and change the configuration @ the Dist, or 2. change the configuration at the ecu, when I made my harness, I was told by mad people to do it @ dist. But It made more sence to me to change at ecu, and not have to fuck with the dist. Maybe this will help, maybe not.
Your problem could only be 1 or 2 things in all reality if all else was done correctly..
I diddent have the conversion here at work but perhaps this will help till I can get home tonight.And I cant upload excel, So I will pm you tonight with the info
Old Feb 18, 2003 | 08:29 AM
coleon's Avatar
RedNeck Refab.Inc
whats your email
Old Feb 18, 2003 | 08:49 AM
2qk4u's Avatar
doesnt the distrib have to be repinned??
i didnt wire my ls/vtec but i swear the distrib had a few wires to move
Old Feb 23, 2003 | 07:17 PM
Stephan's Avatar
Old Feb 28, 2003 | 09:26 AM
Stephan's Avatar
DSM Part Out
