timing belt????
just figured out why the new motor (ls b18b with 98 ls head)wouldn't idle right or have any power what so ever....the damn timing belt is skipping a tooth......i have reinstalled a new belt and the old belt at least 50 times i cannot get it to stop skipping....everything is at top dead center......installed it according to manual......and no go......i cannot figure the damn belt out......i even tried using an gsr timing belt.........what else can i do???
what water pu p are you running? You need to use an ls water pump. Are you tensioning the belt correctly?
Gracie Barra Clearwater
Guest
Posts: n/a
Y0u h4v3 70 u53 7h3 \^/473|2 pump 4|\|d 71m1|\|g b3l7 f|20m 7h3 54m3 3|\|g1|\|3, 13, G5|2 4|\|d G5|2, 0|2 L5 4|\|d L5. 1|\|73|27\^/1|\|3 7h3m 4|\|d y0u 4|23 g01|\|g 70 h4v3 b1g p|20bl3m5.
4l50, pl3453 ch3ck 7h3 5747u5 0f 7h3 71m1|\|g b3l7 73|\|510|\|3|2 5p|21|\|g 4|\|d pull3y 1753lf. 4|23 7h3 c4m g34|25 03M 0|2 m4d3 0f 5733l, 0|2 4|23 7h3y 4f73|2m4|2k37 ch34p 4lum1|\|um 0|\|35?
I am currently having the same problem but with a first gen b-16 bottom and top of the same year. I just cant get the timing belt from skipping. I think the problem is my tensioner. If you get your problem solved post the remedy and if I get mine solved I will post mine.
well i finally got it to work after at least 30 times installing the belt over and over.....boy that was fun......that was the first time i ever had a problem installing a t-belt.....as for an remedy i don't know of one but just to try and try and try i will go sooner or later..play with the tensioner....more than likely you are skipping a tooth on the water pump side like i did....and thanks again for the help!
