B18a or B18b ???
Old Feb 12, 2003 | 06:26 PM
djcrx456's Avatar
Default B18a or B18b ???
I was wondering what is the difference between these two motors that makes the horsepower difference of 130 to 140.
And is it possible to convert a B18a into a B18b ?
-Thanks David-
Old Feb 12, 2003 | 07:25 PM
djcrx456's Avatar
OBD to OBD1 what is that?
Old Feb 12, 2003 | 11:09 PM
01Ls-RTeg's Avatar
Genius v3.015
(on board diagnostics) which is the type of ecu the car has/had in it
obd is less emmissions restrictive than obd 1 both ecu's can be chipped to raise the rev limiter and better the fuel curves but more applications are availble for obd 1
Yes, I do talk to myself, it is the only way I can have intelligent conversations.
Old Feb 12, 2003 | 11:25 PM
2qk4u's Avatar
b18b also comes with da hydro tranny
b18a has cable tranny
besides that everything seems to have been coverd
Old Feb 12, 2003 | 11:26 PM
2qk4u's Avatar
as long as you choose the correct distributor/injectors to match the computer you are using you will be ok. the motors are pretty much the same.
Old Feb 13, 2003 | 09:58 AM
EF18Hatch's Avatar
The B18B head also breaths slightly better ( i think from 93-94 the hp estimates went from like 137 to 142). If you plan on getting it ported then it doesn't matter though. Other than that I think they covered it all.
http://92crx.com
