91 da teg wont go into gear
Old Jul 7, 2014 | 11:15 PM
jdmjim's Avatar
Default 91 da teg wont go into gear
I have a 91 DA that will not go into gear went to shift and would not go in sroped and tried first and same thing if you jam it in you can go but cannot shift help me before I start tearing it apart not sure if its the clutch or what please help
Old Jul 9, 2014 | 12:28 AM
Will it go into gear when the engine is not running?
Old Jul 9, 2014 | 06:07 AM
jdmjim's Avatar
Yes I believe it did when you push clutch it almost feels like a brake pedal cable is fine I got half way apart before I go further wanna make sure
Old Jul 9, 2014 | 01:49 PM
If it goes into gear when not running, next try rocking the car back and forth
with it in gear.
It could be something as easy (and cheap) as a clutch adjustment.
Old Jul 10, 2014 | 04:54 AM
jdmjim's Avatar
The clutch has already been adjusted all way that why I thinking clutch
Old Jul 10, 2014 | 09:01 AM
This might sound dumb, but if it is not going into gear because the clutch will
not release, how do we know it was adjusted in the right direction?
If it is adjusted all the way in the right direction, the clutch will go into gear
easily but will slip.
Any pictures?
Old Jul 10, 2014 | 09:54 PM
jdmjim's Avatar
It drove fine for a year then it felt funny about a week before it happened and it had been adjusted to Haynes specs
Old Jul 12, 2014 | 03:37 PM
No problem. Sometimes the book is wrong. I adjust my clutch for the
way I drive. I have my clutch release high, 'cuz by the time my foot
hits the bottom I have already shifted and I'm on the gas again.
specs
ant87
Jul 12, 2007 01:59 PM
ADAM
Mar 14, 2006 03:41 PM
ccadman
Nissan/Infiniti Tech
17
Oct 19, 2005 02:54 AM
Viper4ug
Aug 10, 2004 04:33 PM
