dumm question
Old May 20, 2014 | 09:17 AM
Junit's Avatar
Default dumm question
probably gonna get beat over this but what exactly is a "mini me" swap
86'toyota corolla
01' lincoln LS my D.D.- gone
04' Mitsubishi Lancer D.D.
94 Mitsubishi mirage- blew up
95 Honda civic eg- new D.D
Old May 20, 2014 | 12:26 PM
Default Mini-Me cylinder heads
We are just talking here. I have an A-series big block two liter in my car.
A mini-me is built by swapping a certain type head onto a certain type Honda block.
What year is your car? What type engine block? Presuming the car is a Civic?
The ports are different.
The Y8 head has swirl type intake ports to promote better air velocity which is helpful at lower rpms. The z6 head has straight or equal ports which is better at high rpm.
Some people say go with the Y8 so you don't have to convert to OBD1, timing gear problem because of the keyway, there are other small things that you can read all about in write ups. Basically your car will run like a factory vtec Y8 whereas if you toss a z6 head up in there it'll cost you more and it won't run as well without some tuning at least.
You wouldn't have to go obd1 because of a z6 head. The y8 dizzy wouldn't bolt up though without cutting one of the legs. But that's not always a problem.
There are no timing issues unless you start switching up cams/cam gears. A z6 cam with z6 cam gear can go in a y8 head and run fine and vise versa. Obviously a z6 head on a y7 block will have no timing issues.
Old May 21, 2014 | 05:46 AM
Junit's Avatar
well have a y8 head and block and was thinking about going turbo , cams,...
86'toyota corolla
Old May 21, 2014 | 06:14 PM
Turbo might produce the most power. Have you looked into a kit?
Old May 23, 2014 | 01:48 PM
Junit's Avatar
Yeah i have been looking just not sure on what turbo trim to go with
86'toyota corolla
Old May 24, 2014 | 01:35 PM
Even though they say everything is always bolt-on, It is almost NEVER bolt-on. lol
Old May 25, 2014 | 11:49 AM
Default Picking a Turbo
Hope this is useful
https://www.youtube.com/watch?v=TLXw3UyfmcI
effDOHC
Sep 21, 2007 02:28 PM
DreamRWDSE-R
Nissan/Infiniti Tech
7
Apr 2, 2004 09:26 AM
ZDriver96
Feb 12, 2002 01:01 PM
