CAM GEAR DEGREE NUMBERS ON Y8VTEC/CRX SI 90 BOTTOM END
HI WAS WONDERING IF ANY ONE OUT THERE HAS SUCSESSFULLY DID A {sorry}mini me swap with a y8 head and a 88-91 crx bottom end.i know you need to use an adjustable cam gear.i have one and am going to attempt the head swap tommorow.i am going to try to line this up at 0 degrees on the cam gear to get it started.has any one had any experience with this kind of swap.any info about degree marks that have worked for you would be helpful.also i want to get an affordable vtec controller.any advise on rpm switches vs.controllers.
