DASH SWAP > 90-91 dash into 88-89 CRX Si
i know i cant fit the 90-91 cluster into a 88-89 CRX
but i was wondering if it is possible to swap the whole dash
i am not worried about any harness issues, thas not a problem
COMMENTS ON THE DIFFERENCE IN THE CLUSTERS ANYONE???
i dont wanna match the cluster to the dash
i have an 88-89 CRX Si
i want the 90-91 Cluster cause of the round shape compared to the flat sides on the 88-89
as you can see in the pictures
The Civic dashes of the same vintage are different than the CRX dashes BTW. You can just do the cluster and cover swap, you will need some different brackets to do so and alot of wiring skill. I've already tried this on a friend's car and deemed it too much of a PITA to attempt again. Good luck with it.
