Have Issues with the engine codes..
Old Mar 11, 2013 | 02:54 PM
drunkle's Avatar
Default Have Issues with the engine codes..
I have recently gotten three codes on my obd1 p75 ecu. they are code 3,6,and 10. I looked up what they where and replaced them all but yet i still have two codes remaining my coolant temp sensor (which is new) and my AIT. my map sensor code disappeared once i put in a new AIT. i dont know what to do anymore. Any suggestions?
Old Mar 16, 2013 | 02:21 PM
jdm_goon91's Avatar
have u reset the ecu?
$EG CREW MEMBER #52
Old Mar 18, 2013 | 04:02 AM
drunkle's Avatar
I thought the ecu resets its self every time you turn on and off the car? Do you know a way to reset it?
Old Mar 18, 2013 | 07:06 PM
jdm_goon91's Avatar
well, i had a problem with my crx throwing radom codes i couldent diagnose the problem took it too a shop they said its throwing codes cuz i had some sensors bad.. replaced them still was throwing random codes i did research.. they said to disconnect the battery for 30 seconds i did.. still didnt fix it..then i decided to disconnect my ecu and it worked..couldent hurt to try it
$EG CREW MEMBER #52
Old Mar 21, 2013 | 02:00 PM
drunkle's Avatar
hmm yea your right wont hurt to try will try that next see what happens. i just order a new wiring harness becuase i bought this car with swap in it and the harness is in pretty bad shape. i was thinking maybe that could possibly b what it needs. Thanks for the insight.
ugmSTI433
Subaru Tech
17
Oct 23, 2009 08:56 AM
tphitterlude92
Feb 6, 2006 05:39 PM
aj187
Apr 27, 2004 03:27 PM
91IntegVtec
Feb 5, 2004 04:34 AM
