engine codes....
how do i throw the codes to a 91' crx??
[url]
69 Buick Skylark - Brokeded
91 CRX hf (zc dohc swapped) - wrecked/fixed-wrecked/fixed-wrecked-sold
91 Civic hatch (stock) - Sold
91 CRX hf (ls swapped) - Traded
90 Civic Hatch (mini me) - Sold
91 CRX si (zc dohc swapped) - Brokeded
02 Dodge Ram - gave to repo man
06 gsxr 600 - Wrecked
95 cbr f3 (stunta) - Sold
96 Integra ls - Sold
94 Integra ls - Sold
02 Dodge Ram - Daily
[url]69 Buick Skylark - Brokeded
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
thanks.
[url]
well the led was blinking normally.. means nothing is wrong?
[url]
how many blinks are you seeing? are there pauses and then it starts again?
...91 SMF SCCA
no its just.. blink.. blink.. blink.. over and over..
[url]
AJ- if your ECU led display is blinking then your throwing codes . . 1st pull the hazard fuse or disconnect the battery for a bit then reconnect and see if any codes are still displayed . . .
ok..
[url]
on a 91 HF it should be just blink blink blink. so after you have reset the ecu, as described, then see if it is still blinking.
counts the number of constant blinks and there is your code. if there is more than one code being thrown there will be a pause and it will start again.
...91 SMF SCCA
