hydrolic tranny swap in ef, HELP
Old Dec 5, 2012 | 02:16 PM
allmotorEGhatch's Avatar
Default hydrolic tranny swap in ef, HELP
Swapping a z6 transmission into my car
have everything in the car all swapped . I have innovative mounts for hydro tranny in ef
after i torqued down the axle nuts hubs wouldnt turn . Backed off driver nut and hub turned , but nothing still on passenger side .
I used a driverside axle from an 94 del sol , passenger side is fron an ek . Do i need to use axles from an ef ?
Need to know ASAP !
'75 Mercedes 240D A.K.A Hitler-Mobile - Blew Up lol
'02 Ford Focus - Sold
'93 EG Hatch D16Z6 - Traded
'89 CRX GSR - R.I.P. ):
'94 Nissan Hardbody - Traded
'94 Del Sol D16Z6 - Sold
'92 EG Hatch B16A - Traded
'90 EF Sedan D15B VTEC - Sold
'94 Del Sol D16A8 - DD/Project
'00 CRV - DD
'99 CL - DD
Old Dec 23, 2012 | 08:41 PM
Default some things to measure
I would compare axle lengths that you have installed with
the axle lengths that you took out. Most of the time there is side to
side play in the axle that allows the axle to compress/expand in length
to let the suspension rise and fall as you drive over bumps.
I would compare the distance in both transmissions for how far apart
the differential is inside both of them. If it turns out that one differential is
"wider", then that would cause binding.
I have never heard (until now) that torquing down axle nuts would stop
the axle from rotating. Try looking on the back side of the hub for
something that is rubbing or interfering with the axle when it is tightened
down.
Plan B is to loosen up the axle nuts until the axle rotates, then torgue them
down in 5 LB increments until you start to feel some drag, then start
looking for the interference that prevents the axle from turning.
Plan C is to hit the internet searching for your tranny swap, and see what's
the most common reason for axles not turning.
Post up what you find, so we can all get smarter.-Bob
Secondz
For Sale/WTB Honda & Acura
4
Feb 3, 2012 10:19 AM
CARLOS V.
Nov 18, 2009 01:03 PM
Boostedjdmeg
Aug 30, 2008 08:32 AM
