Cooling fan
Old Jan 18, 2003 | 07:36 AM
joecivic's Avatar
Default Cooling fan
The coolant fan wont turn on in my car. I changed the relay and I still cant figure out why it wont come on.
Any ideas?
Thanks
Old Jan 18, 2003 | 02:09 PM
cykociv's Avatar
Up and running
Have you applied power to it and made sure that the motor is good? Take is to Honda and let me tell you. Once they tell you fix it your self. It the part costs to much just in stall a switch.
" Nitrous is like a hot chick with an STD, you wanna hit it, but you know what the consequences might be "
Old Jan 18, 2003 | 06:17 PM
Boosting240's Avatar
burn't fan motor or possible radiator fan switch i think
.................WHAT NOW ?...............
Old Jan 19, 2003 | 10:17 AM
joecivic's Avatar
Yeah I hooked up a manual switch to it and it works fine. Well it looks like I'm gonna have to just hook up that switch again.
Thanks
Old Jan 19, 2003 | 10:40 AM
StreetDriven's Avatar
I <3 your mom
Thanks
yup thats what happened to mine i had a bad wire somewhere so i just hooked up a switch.
Old Jan 21, 2003 | 08:24 AM
1QWKCRX's Avatar
That CRX Guy
A big problem that is over looked is the fan relay. A very cheap and simple solution, these have a tendency to go bad over time. It is a small black box about 2"x1 " and is located next to your air inake.
Florida CRX Meet 2011 http://www.facebook.com/pages/Florid...2354313?ref=ts
Old Jan 21, 2003 | 12:44 PM
BIG_Truck_Driver's Avatar
Wherever I may roam...
on the thermostat housing there is a 2 wire plug, it goes to a thermal switch, with the car running unplug it and short the 2 wires inside the plug, if the fan comes on the thermal switch is bad, if not then it is in the wiring or the relay.
