Vss Sensor 94 H22.... Suggestions??
Old Jan 8, 2003 | 10:56 AM
coleon's Avatar
RedNeck Refab.Inc
Default Vss Sensor 94 H22.... Suggestions??
In middle of a Swap and in my non-ODB car dosent have a an electronic Vehical Speed Sensor, I was told I could take the electronic sensor out and put my cable in and some sort of gear will turn my cable? Any Help would be cool. Thanks
Old Jan 8, 2003 | 11:38 AM
crix's Avatar
:mugen member:
there is a 10mm bolt holding the speedo gear down
remove the bolt & replace the vss with the cable driven gear
that should fix your problem...
Old Jan 8, 2003 | 01:34 PM
coleon's Avatar
RedNeck Refab.Inc
I will def. check it out, Thanks
