what is needed for a 96 b18c1 swapped into a 2k civic ex
I was told that i would need an obd2-obd1 harness, what else is needed for this type of swap, what should i watch out for? the swap is complete, ecu, trans, mounts, etc... Is the harness the only wiring modification needed for this swap? thanks for the info
if this is the same person i was relaying info to through a.j. , call me
chris
813-918-2291
chris
813-918-2291
BTW:
you dont have to have obdI to obdII harness, but you'll hate not having it!!!!
OBDII = :thumbdown:
chris
OBDII = :thumbdown:
chris
