need a wiring diagram/ecu pinout for 95 civic,auto...
Old Jun 17, 2012 | 02:38 PM
My Honda Is Slow's Avatar
No really,....it is
Default need a wiring diagram/ecu pinout for 95 civic,auto...
yes, i have searched for hours and found some good ones but none help with my problem. i need to know where to pin the 2 solenoids on the transmission so my car will shift...
its an auto engine and trans in a 5spd car so it doesn't have the pins for the shift solenoids...and all the diagrams ii have found just say "A18=for A/T" doesn't say what it controls or anything exactly. the tcm should be built into the ecu on po6 ecu's so i just need to know which pin to hook up each solenoid.
thanks in advance...
and this is the stuff i have been finding....like this.
B3- Orange, upshift/downshift comparative input, N/A
B4- Pink, upshift/downshift comparative input, N/A
like should i hook a solenoid to each of these and which one to which. i always thought both solenoids did the same thing so shouldn't they hook to the same pin on the ecu? i thought all it did was lock up the torque converter when it was time to shift....
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Jun 18, 2012 | 10:53 PM
BoostedRacerDad's Avatar
Pops
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Jun 19, 2012 | 02:48 PM
No really,....it is
holy shit. thats perfect! your the man. just one question. any idea why it lists 5 transmission solenoids? mine only has 2 that are together on the front of the housing just under the head...
Old Jun 20, 2012 | 07:03 AM
Pops
I knew you were going to ask that, I had the same question after looking at print. At first I thought it was a shuttle valve utilizing A and B ports but it is not... It is a generic print out of the official manual that covers multiple years and is showing you also how to hookup 92-95, 96-2000 which has 4 solenoids. Yours was hard to find as you know you don't use a TCM but is controlled right from the ECU. Download the official manual and go to section 14 and it will have everything you want and more.
JoKie TuNinG
StricKlyMT
727-510-6301
Old Jun 20, 2012 | 05:13 PM
No really,....it is
i got it! your the fucking man sir....cant thank you enough. i ran the codes and only had code 19 which was solenoid lock up. so i ran my 2 wires to the solenoid lock up pins and its shifting perfectly. still have a cel though. not sure why. maybe it needs to see them working for a few miles?
dutchmastazero
Aug 23, 2008 09:05 PM
Croba_Killa
Audio HQ
Jun 5, 2007 08:14 AM
TurboJZA70
Jan 5, 2004 06:46 PM
art
Dec 30, 2003 07:41 PM
MR2driver
Sep 29, 2003 07:19 AM
