Need help with ac
i have a 96 integra and was told all i needed to do was recharge the ac system..
so i went to the autoparts and bought a can of the refrigerant thing and put it on the port by the radiator.
when i was putting the liquid in there was a loud hissing noise by the two lines that enter the firewall..
idk what is was but i checked it and the lines do not leak...i checked the inside of the car under the dash and no leak
either so what could it be???? i left the ac on full blast for 10 min and nothing...still comes out hot...
HELP!!!!I NEED AC
HELP!!!!I NEED AC
It sounds like maybe you need the O-rings replaced where the hoses connect.
When I hear a hissing, it usually means a leak.
It's not a bad idea to suck out the air before adding refrigerant.
In what way did you determine there was no leak in the lines?-Bob
