AEM fuel rail will not accept RC 330 injectors...
Old Mar 29, 2012 | 05:06 PM
wolfenr1984's Avatar
Great White Hope
Question AEM fuel rail will not accept RC 330 injectors...
So, I'm in the process of swapping out my stock, poorly fitting fuel rail with one from AEM but I have run into a problem. The RC 330 injectors with OEM seals will not fit into the AEM fuel rail without getting cut. I tried oil, coolant, and some spit to slide them in, with no luck. What am I doing wrong?
"The richest man is not he who has the most, but he who needs the least
TR "Old Skool DA" Member #28
Old Mar 29, 2012 | 07:15 PM
Great White Hope
So, come to find out the old injectors do not fit either. I think I may have gotten a defective rail...or maybe AEM has a bunch of bad ones?
Old Mar 29, 2012 | 09:09 PM
2qk4u's Avatar
i doubt the rail is defective the prob sent you the wrong one does it have a part number on it
Old Mar 30, 2012 | 03:46 AM
Great White Hope
True. Yeah, it does have a number but it's nothing like the part numbers they advertise. I'm going to call them.
Old Mar 30, 2012 | 06:04 AM
Great White Hope
So, come to find out that the rail is correct, it's just that the holes were not drilled big enough. Stock injector holes are slightly larger and tapered, allowing the seals to slide by and fit correctly. I may take the rail to a machine shop to see if they can make the holes bigger.
riptosredek
For Sale/WTB Honda & Acura
31
Dec 9, 2006 11:05 PM
bigmike1
Nov 1, 2005 03:17 PM
