mini me problem
ok did a standard mini me set up on my crx. A 95 sohc vtec civic head on a 91 dx bottom end with an si distributor. Wired everthing up, slapped on the distributor. Try to start the car, it's trying to turn over but no spark. We find out nothing is wrong with the ecu or the wiring. The ecu throughs a code 15 and a code 8 which is the coil and the igniter inside the distributor. So we replace thoose 2 things in the distributor. try to turn the car over and no spark. the ecu is not throughing any codes out this time so the problem is fixed but my car is not running. any ideas on why im not getting spark?
HAHA, to bad i built my whole motor while pat was at his house.
i did call him a few times. but he never turned 1 bolt on the motor.
he wired the vtec, ecttt and fixed my wiring massacre.
i forgot patrick told me he did ur swap.
call his ass then.
call his ass then.
