someone please help me 95 accord starting problem
Old Feb 19, 2012 | 04:03 AM
jdmjim's Avatar
Default someone please help me 95 accord starting problem
OK got 95 accord just cranks but wont start it gets fuel and spark if I spray starting fluid it will start please tr help me
Old Feb 19, 2012 | 04:51 AM
jdmjim's Avatar
Ttt
Old Feb 19, 2012 | 06:03 AM
flatrex's Avatar
crx hatch sedan
Are you absolutely sure you're getting fuel....check timing I guess
Old Feb 19, 2012 | 06:10 AM
jdmjim's Avatar
Am sure just did timing again and after its been running it will start right up
Old Feb 19, 2012 | 07:19 AM
flatrex's Avatar
crx hatch sedan
Hmmm have you check all the simple stuff like fuel filter and fuel pressure..
Old Feb 19, 2012 | 08:11 AM
BoostedRacerDad's Avatar
Pops
I am thinking bad main relay. Injectors are not pulsing. See if they click.
Print shows a fuse for fuel injectors check that first
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Feb 20, 2012 | 01:54 AM
vtec727's Avatar
prolly your timing what did u do to it
Old Feb 20, 2012 | 04:36 AM
jdmjim's Avatar
Redid timing it is on the money what about ignition coil I keep reading this us a common thing for accord
Old Feb 20, 2012 | 10:01 AM
flatrex's Avatar
crx hatch sedan
Boostedracerdad is probably right ....
Old Feb 20, 2012 | 04:49 PM
Blue92ludesi's Avatar
if it works when u spray starter fluid then its obviously not the timing, nor the coil...... Start with Main relay.
Honda of Wesley Chapel Crew Member #1
TR 5th Gen Civic CREW Member # 07
TR H2B crew #2
__________________________________________________ _________________________________________________
quiksilvia
Nissan/Infiniti Tech
4
Sep 27, 2010 09:26 PM
LShatch98
Jun 15, 2008 12:49 PM
iburnv8s
16
Apr 28, 2006 06:49 AM
425cicamaro
6
Nov 13, 2004 04:21 AM
