put new clutch in and all gears bounce off 2 step
If your speedometer is not working, you will be stuck in 2 step in every gear.
The vss signal may not be getting to the ecu.
Contact who ever you got the ecu from for a solution.
Yes, if the problem is in fact that the car is staying in 2 step because of a faulty vss signal, the only solution is to disable the vss based 2 step.
