VTEC not engaging properly...
Old Dec 5, 2002 | 08:09 PM
FerioVtec94's Avatar
what do you mean your vtec light? you have a light for when vtec comes on? whats the point of that?
Old Dec 5, 2002 | 10:00 PM
drift's Avatar
Hatorator
check your oil level after double checking your wire connections.
1997 Prelude, H23A1 VTEC
Items for sale:
H22/23 block and all internal parts
4 5th gen Prelude wheels, 16x6.5, 5x114.3mm bolt pattern
More stuff for sale:
https://www.tamparacing.com/forums/showthread.php?s=&postid=472993#post472993
Old Dec 6, 2002 | 04:33 AM
drift's Avatar
Hatorator
Originally posted by "CronicBurn"
My oil is fine. I checked the wire connection, there's only 1.
no, not just the light connection... fuck the light
can you hear the motor if it's going in and out of VTEC? does the motor seem to "stutter" at all? if not, then it's something to do with the light. maybe the LED connection in the instrument panel. if it's a cheap LED setup, the LED may not be matched for automotive voltage, and could be burning up.
now if something tells you that VTEC operation truly is becoming dysfunctional, follow below.
check the VTEC solenoid wiring all the way back to the ecu with an ohm meter... wiggle the wires around and check for a possible intermittent connection.
if that's all good, then remove the VTEC solenoid and check the filter screen. if it's clean, replace the solenoid.
the solenoid and VTEC oil pressure are both monitored by the ECU... if something truly is wrong, you should have gotten a fault code. if you need a new solenoid, refer to my sig.
Items for sale:
Old Dec 6, 2002 | 08:48 AM
2qk4u's Avatar
im with him tenacious on that one
is there actually anything wrong,, bucking,hesitating, ect...
Old Dec 6, 2002 | 10:27 AM
is it possible to have a LED light that brightens up to different amounts depending on how your car is running?
