Need a good machine shop for head resurfacing
Old Dec 5, 2002 | 06:00 PM
Bill's Avatar
Livin' in Seattle
When you mill material you WILL end up with tooling marks. These are not anything to be worried about unless they are deep enough to catch a fingernail being run over the surface. I would doublecheck the install first before getting any more material removed from the head.
Old Dec 5, 2002 | 07:40 PM
2qk4u's Avatar
napa sucks dick. they sooooo fucked me a year ago on a bore/hone
my cylinders were so fucked.
i got a guy who can do it right.
334-6164
jason
napa charges 60$. so if it ends up needing to be redone it will be 50$ or less. and i will pick up and deliver the head if you are local.
i toss this guy work and he hooks me up.
he has a serdi valve machine and like 100k worth of equiptment.
he does excellant work
Old Dec 5, 2002 | 07:41 PM
2qk4u's Avatar
and if you use to much oil on the bolts the wont torque down all the way
Old Dec 7, 2002 | 08:31 AM
letsrollagn's Avatar
BRT OVERKILL
its pretty common for it to leak there, no big suprise napa screwed something else up, try 2qk4u's guy he is good, or go to Eisles.....
Old Dec 7, 2002 | 09:10 AM
2qk4u's Avatar
eiseles sucks dick to.
they just bore your block to whatever the fuck they want to
and they make everything at the loose end of the tolorances so there is no chance of them being responsible for any fuckups which is fine.
but when im building a race motor i need my clearances tight.
