Break in Question
Originally posted by "RavageEJ6"
so which piston bore would that be?
Bore 3.189
Bore 3.199
Bore 3.209
thanks
Hartman
Bore 3.189
Bore 3.199
Bore 3.209
thanks
Hartman
81.25mm would be good for stock sleeves, 81.5 mm might be taking a little too much out of the sleeve on an fi motor
Gracie Barra Clearwater
hartman, do you have a head for it already? if not i have a spare ls head with full valvetrain you can get for chep.
Eat a live toad every morning, and that will be the worst thing to happen every day.
I don't know the max an ls rod can handle. If you wanted to use your stock rods the least I'd do is:
shotpeen the rods $40
arp rod bolts $50
resize rods (needed when installing new rod bolts) $40
that is $130 right there and then compare that to about $350 for a set of Eagle rods that can easily handle 15psi.
The choice is yours.
arp rod bolts $50
