oil pan wont seal!!!!!!!!!!!
Old Nov 29, 2002 | 05:58 PM
NChatch's Avatar
i stepped on my weiner!
Default oil pan wont seal!!!!!!!!!!!
guys i have taken off my oil pan and used an OEM gasket and hondabond and still have a little trickle of oil running into the bottom of my tranny the thingis i spent mad loot on a clutch and dont want it covered with oil AGAIN. any ideas or solutions are much appreciated
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
Old Nov 29, 2002 | 07:30 PM
Nata$'s Avatar
TR Balla Donor Supreme
Are you positive its the oil pan? If so then try RTV sealant
Old Nov 30, 2002 | 06:19 AM
NChatch's Avatar
i did i even spent the money on "HONDABOND" and i still have a trickle every now and then, i have never seen an oil pan kick my ass but this one sure is
owner/operator
Old Nov 30, 2002 | 10:50 AM
KJ's Avatar
KJ
bored at work
sounds like rear main seal. Happened to me before PITA.
Old Nov 30, 2002 | 03:41 PM
Bill's Avatar
Livin' in Seattle
Double check the pan gasket before going out and blaming the rear main seal. Make sure the gasket isn't mushroomed out from overtorqueing it.
Sometimes a the Honda torque specs for pan gaskets can be a little too tight.
Old Nov 30, 2002 | 04:04 PM
FerioVtec94's Avatar
i had the same problem a couple days ago, i kept thinking it was the oil pan seal, it wound up being the crankshaft seal.
Old Nov 30, 2002 | 07:11 PM
racin's Avatar
ZMR
There's also 2 more seals to check oilfilter seal behind your oilcooler and you shifter seal where it connects to your tranny....
ZMRacin...for the people since 1998.
typeZ zionmotoracin@gmail.com
> #zionmoto #s1built #battlegroup3<
drag honda / drift soarer / road race benz
Old Dec 1, 2002 | 02:50 PM
NChatch's Avatar
thanks yall, when i put in the clutch i put in a new main seal cause i wasnt gonna go all the way back in for it, im tired of clutches..........3 clutches 3 weeks.........
finally one that works,
thanx
owner/operator
