LSt progress so far
Guest
Posts: n/a
so far ive gotten
t3t04e turbo
fuel pump
turbo timmer
dsm injectors
resitor box
boost controller
im debatin on finishin the tubo parts off first
or should i start on the block?
or at this time it really doesnt matter
also this is a debate between me and '92cxhatch
snice im only gonna run 8-12psi
do i need 3" all the way bak or 2 1/2?
what turbo mani do yall suggest?
drag mani?
any other opnions are welcome
thanks
Hartman
t3t04e turbo
fuel pump
turbo timmer
dsm injectors
resitor box
boost controller
drag mani?
thanks
Hartman
Guest
Posts: n/a
There is a rather large difference in power from 8-12psi. If your planning on running that much, get at least rods and forged pistons. Head studs, and rod bolts are also advised. I'm still a newbie to this too, but better safe then sorry. Any slipups in boost could be deadly to your motor. Also, go w/ 3" exhaust pipes to be on the safe side. Finish up with your turbo equipment first, get your IC and plumbing, then work on the block.
IMO 2.5" exhaust should be fine. you wont run into any back pressure issues at that boost setting.
i'd consider 3" if you were planning to boost closer to 20psi. 3" may cause boost creep at your boost settings, altho it would be relatively controllable with the proper equipment.
considering the output of a 1.6-1.6 litre motor, 2.5 should be just fine. i've worked with a bunch of 2.0-2.2 litre motors that were forced induced with 2.25" exhausts without any backpressure issues.
1997 Prelude, H23A1 VTEC
Items for sale:
H22/23 block and all internal parts
4 5th gen Prelude wheels, 16x6.5, 5x114.3mm bolt pattern
More stuff for sale:
https://www.tamparacing.com/forums/showthread.php?s=&postid=472993#post472993
Items for sale:
Guest
Posts: n/a
ok im gonna do 3" all the way back
i want 8psi for low boost
and 12psi for high boost
ive been planning on doin forged internals
on my block from the begining
im still debating on the BOV
ive heard alot of crap about the greddy type s
but then again i dont think ill eva use the otheres
'to their full potentiat so will they be a waste of my
money? ie greddy type r and hks ss or the tial bov
other wise when im doing the swap what other shit should i
have around? i got wires plugs oil and shit like that
snice the car is a 98dx will i have to have anything wired?
Hartman
Hartman
