Crx with B16
Re: Crx with B16
Originally posted by "cobos"
Now let's just say i had an 88 CRX HF and i swapped in a b16 and had some decent traction, about what would i run in the 1/4?
depands on alot of things.
First of all, what type of wheels and tires. If you are running on some 13's VX with some advan tires. Your gonna hook at higher RPMs. You got to remember, when you take off at higher RPMs you need to feather the trottle and clutch at the same time. Basically, practice your launch techniques. The second would depends on mods of the motor and tranny.
Take everything in consideration. I have a friend in a '88 HF with a stock exhaust manifold, home depot air intake and custom cheesy exhaust that did ran a best of 13.8 @ 96 mph. Hooking up and taking of the line correctly was his main key. Hell, I used to hit 13.8 @103 mph cause I wasn't able to hook up of the line. A big difference.
Practice, practice and practice
be careful though bro, the little single cammers make just enough horsepower to get a clean launch and will alot of times pull you out the hole and keep the distance the whole way, i should know i have had a b16 crix, and a H/B sohc. best thing right now is to get some VX wheels and cover them with nittos, and make sure you have a good ass clutch, do this and use the HP you make, and get it to the ground
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
