D16y7 ek transmission HELP!!!!!!!!!
Old Oct 25, 2011 | 05:26 PM
SP33DDEMON19's Avatar
Default D16y7 ek transmission HELP!!!!!!!!!
FIXED THE ISSUE IT WAS THE INPUT SHAFT BEARING>>>
ok so this is my problem and all that i have done to try and fix the problem and still no luck.. PLEASE WATCH VIDEO
its a d16y7 motor and trans
its been making the noise since i bought the car about 9months ago about 25,000+ miles (yes i drive alot)
i thought it was a simple throw out bearing (tob) since when i push the clutch in the noise goes away and when i let off the clutch it makes the noise
1st. 6/15/2011 I went and bought a oem replacement clutch PP tob bearing behind the flywheel.. and driver side axle change everything and put everything back together still made the noise FML
2nd 10/20/2011 i went and got a z6 trans from a friend (so i knew it was good) changed it still made the noise FML
3rd 10/20/11 pull the axles out thinking maybe a it was a axle that was not sitting right still made the noise FMl
4th 10/21/2011 went and pickd up a tob and fork and put the old y7 trans back in the car still made the noise FMl
5th im asking TR what do you think the noise is ???????????
Here is a video of the noise listen to it ( its making the noise than i push the clutch in and it goes away).......\\\
*** I make decals on the side check me out thanks!!!
http://www.facebook.com/#!/pages/Stickers-OR-Die/121288637937818
Old Oct 25, 2011 | 07:53 PM
chinkyeyeguy's Avatar
sounds like a throwout bearing. same thing happened to me, mine was making a noise. changed it out with a brand new one and still does it.
Old Oct 25, 2011 | 08:43 PM
Sno Wyte's Avatar
Kenpo Master Technician
sounds like an input shaft bearing to me
Old Oct 26, 2011 | 04:41 AM
integra's Avatar
90% grind 10% sleep
+1
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Oct 26, 2011 | 06:29 AM
I have changed the tob. 3 times already. From the one that came wit the car to the new one. Than another new one still made the noise. Thought about the input shaft bearing. So i chnagd the entire transmission still did it. Does anyone think the flywheel could make the noise???
Old Oct 26, 2011 | 06:39 AM
integra's Avatar
90% grind 10% sleep
Did you change the pilot bearing on the flywheel?
Old Oct 26, 2011 | 07:00 AM
Yes i did when i changed the clutch.
Old Nov 8, 2011 | 06:27 AM
ekhatchboy's Avatar
Redrocket part 2
what kind of pressure you getting at the pedal? everything seem normal? its possible both trans. have bad input shaft bearings... g/l
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Old Nov 8, 2011 | 01:50 PM
^^^ ya figured it out both trans had the same bad input shaft bearing...fml but everything is fixd i pickd up another trans and everything works fine now...
Old Nov 12, 2011 | 09:00 PM
lzylst's Avatar
Typically a bad ISB will have a noticeable whine in 1st & 2nd. Or if it is real bad you can grab the input shaft and move it around before installation of a trans. I have seen more single cam trans have this issue. Maybe it is due to a smaller bearing than DOHC.
Vance @ 863-604-2139 for any questions
