b18a1 HELP!!!!
My swap it turns on and everything but it iddles high as hell I can't tell u exacly how hight cus my speedomiders ain't connected..and also wen I hit the gas it iddles a lil higher then it acts like it has a 2step ecu.the ecu is bliking red code 4 and 9 and I have no idea wat that means and I donr kno wat to do with these problems help tr
http://i36.tinypic.com/2jabubl.jpg "TR Old Skool EF" Member #219 JDMASFUCK
DD.miata fastback top
well code 4 is crank position sensor.
and 9 is cylinder 1 position sensor. which can be bad wiring from the distributor.
are you sure its not throwing code 14? cuz thats the iacv and that would cause the high idle.
2000 Prelude- Totaled
1993 Del Sol Si- Sold
1992 B20 Integra- PIA
1998 Integra LS- Current
No not 14 it blinks 4 then it stops and then it start to blink again 9 more times..and the wireing was done not to long ago by neal iidk if u kno who that is but idk wat can I do to fix this mess its my dd and I have a job to drive to everyday
I don't kno what any of this is this is my 1st time having this prob with any of my cars and it was my 1st swap aswell.pm me with contact num so I can get more info bout these vacs and screws
Anymore info for my problems???
the fitv is gonna be on the bottom of the throttle body if its an obd1 swap. the iacv is on the back of the intake manifold. just take them off and clean with carb cleaner and see if it helps any.
then just recheck and make sure the other sensors are plugged right and have power getting to them
Nice thanks for the info good details bro.
check that all your vacc ports are plugs or ran and not leaking
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school
PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
Current Cars
PM me for info.95 Civic EX 4dr- D.D.
no 1 else thought about it...check ur map sensor...it might not be connected to the vac line.. seen that happen on another car and everyone was looking for a bigger problem. plug it in problem solved...if not id say its a vac line somewhere else
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
95 Eagle Talon ESI
90 Acura Integra LS
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
